Calls to my wife's cell number is routing to my voicemail
aip0401
Hi everyone,
I'm not sure if someone can help me with this, but the other day, my wife call-forwarded her number to mine (she's on Telus while I'm on PM).  I didn't change anything on my iPhone.  My wife has already turned off call forwarding on her iPhone, but whenever I try to dial her number on my phone, I get sent to my voicemail instead.
We have tried toggling call forwarding on her phone a few times and restarting our phones, but I still get directed to my voicemail.  Is there anything that can be done to correct this?
11 REPLIES 11
@Ando wrote:
@aip0401
take out both sim and put in each different phone and see if works.and put them back.
That couldn't have helped because call forwarding is set at the network end before the calls even gets to the phone.
@aip0401
Thanks for letting us know. Backend issue then.
aip0401
Hi everyone, I appreciate all your help. My wife ended up calling Telus support and they resolved things on their end. It appears that, when she disabled Call Forwarding on her phone, the command didn't fully go through on the backend, which led to a situation where I was still getting some of her calls and other calls were going through to her phone.
@aip0401 before you open ticket wirh PM support   try this
Set Foward when not available  (or even Foward all) to one of the VM numbers in this post and see if it works
https://productioncommunity.publicmobile.ca/t5/Get-Support/Updated-list-of-Voicemail-Access-Numbers/...
Another thing you can try is to click Reset All Network
aip0401
Unfortunately, that didn't work either.
aip0401
We've both tried.  Unfortunately, there's no improvement.
aip0401
Yesterday, it seems like a few calls to my wife were going to my phone even though Call Forwarding was off on my wife's phone.  Today, one of her friends tried calling her number and succeeded.
@aip0401   Try to dial ##004#.  It will reset all forwarding settings to default
Meow
Which phone other people get when they call your wife? Goes to your phone?
@aip0401 wrote:
Hi everyone,
For call forwarding settings to be changed, these parameters needs to be sent through the network. t appears that for whatever reason, Public Mobile isn't updating the settings or hasn't receive the request.  It's also possible that there's some type of delay, and that the issue might correct itself.
@aip0401
Try rebooting both of your phones by powering them off then back on (by holding down the power button and power off).
See if that works.
