02-15-2023 07:02 PM
Can anyone tell me if the 1000 UK minutes add-on allows calls to both cell phone and landlines. Thank you
02-15-2023 09:50 PM
Sorry I have only just got my SIM card so did not qualify for any Xmas freebies - pity !! I am not unhappy with the price of the add-on for UK calls especially as they do not expire
02-15-2023 07:25 PM
Were you here in December? Did you get the more is merrier freebies? The long distance part would allow you to call the UK. No need to buy the add-on.
02-15-2023 07:16 PM
@BritinNB wrote:Thanks for your quick reply but I would really like to know the answer before I spend my money on the add-on. It is not much use if the connection is limited to landlines only
Why don't you ask agent for clarification and confirmation?
To Contact CSA-agent; there are 2 methods:
Ticket has to be opened through chatbot - https://widget.telus.tiia.ai/publicmobile/publicmobile.html
Having a ticket is preferred way to contact agent as they might respond faster then receiving personal mail.
If opening a ticket does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking (Ctrl+)Here
Agent’s response is usually between 15 and 120 minutes with a ticket. Private message might take longer.
02-15-2023 07:16 PM
02-15-2023 07:14 PM
Many thanks, I'm grateful for your answer. I will go ahead a buy the add-on minutes, they are very good value
02-15-2023 07:14 PM
@BritinNB Go ahead and buy.
YES .PM is prepaid and usually do not provide refund. But if it is no fault of yours, just it cannot be called some specific number (except those stated on the restrictions I posted above), you can open ticket with PM will and they likely will "take care" of it and reverse the transaction
02-15-2023 07:12 PM
02-15-2023 07:12 PM
@BritinNB you can call BOTH landline and cell phones.
But there is one restriction:
**Calls made to numbers starting with the following UK codes are not included in UK calling from Canada and will not be completed when dialled: 4470, 44870-44879, 44843-44845.
02-15-2023 07:09 PM
no mention of restrictions so give it a go.
