12-01-2024 08:01 PM
Hi, I just just activated my account and ported my phone over (waited to respond yes with the old carrier before switching sim cards) . It has been over 7 hours and I still can't receive calls or texts on my phone number. Chat is a nightmare to navigate and I created a ticket but can't even find a trace of it. Would it be in messages? Thanks in advance
12-01-2024 09:16 PM
Will do! Thanks for all your help!
12-01-2024 09:12 PM
use this directly link
12-01-2024 09:05 PM
Hi , I don't see an envelope icon anywhere
12-01-2024 09:03 PM
Ok maybe I'll try again tomorrow if it doesn't work. As both agents gave me the same answer. I waited on hold
12-01-2024 08:59 PM
if you successfully sent your message to Customer Support, watch the little envelop icon on top right side of the page will be highlighted when they respond.
12-01-2024 08:59 PM
hi @Stevenolah71 we gave this to everyone and most got it sorted. It is true sometimes they got to some agent refused to help and thought they couldn't help.
But anyway, message support as advised above
12-01-2024 08:57 PM
Sorry one last question. Is there anyway to see my ticket that I created?as I don't see it anywhere. Thank you so much for all your help!
12-01-2024 08:47 PM
They said they have no access to public Mobile and everything must be done through this website. Why is this so difficult.
12-01-2024 08:36 PM
Ok thank you!
12-01-2024 08:35 PM
hi @Stevenolah71 we gave the number a lot and they all got sorted. you can call again and hope another experienced agent knows
at the same time, open a ticket with PM team just in case.
you can submit by direct message:
12-01-2024 08:28 PM
When I called they said they don't have access to Public Mobile
12-01-2024 08:18 PM
Ok thanks! it is ok that this is saying Telus on the phone line? I have been trying to get through to someone on their very glitchy chat all day. It's very frustrating.
12-01-2024 08:17 PM - edited 12-01-2024 08:17 PM
yes, that sounds like porting problem. Please contact the team I sent you. Once that port is completed, reboot the phone and you can try send text. (The sent text problem could be iMessage or RCS unable to register/confirm )
and Telus owns Koodo and PM, same porting team
12-01-2024 08:16 PM
This number is for Telus. I have never had so many issues trying to navigate information. I work in customer service as well.
12-01-2024 08:09 PM
Hi I can call out only but not receive any. I also can't receive or make texts.
12-01-2024 08:03 PM
can you make calls? If you can make calls and just not receive calls, it is problem with Porting. Did you receive a text from your old carrier and did you reply Yes to them
PM porting support team can help to confirm the porting status I have sent you the porting support team number. Please check your Community inbox (https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage), check for the number and call
