01-14-2025 10:03 AM
03-11-2025 09:46 PM - edited 03-11-2025 09:54 PM
Where are those instructions?
EDIT - Found them
Thanks
03-11-2025 05:59 PM
Cell phone international protocol calling is +Country code Area code xxx xxxx
For example to call a number in Toronto Canada is +1 416 xxx xxxx
Calling a number in Germany would be +49 xxxx xx xx xxx
The + is decoded automatically to the international long distance access code in the area you are calling from
It is a good idea to precede all your contacts with the + and country code. The system automatically translates if it is a local call or long distance call.
01-15-2025 01:46 AM - edited 01-15-2025 01:47 AM
I am in Mexico now and found that when calling Canada by dialing 1 and area code and 7 numbers the call would not go through.
but if I dial +1 and area code and 7 numbers the call does go through
01-14-2025 10:56 AM - edited 01-14-2025 10:59 AM
01-14-2025 10:55 AM
I got it working, the key is to use a + in between the 00 exit code and 1 north american country code. So a number would be inputed as 00+1<area code><7 digit number>. You have to actually dial the plus sign, it does not mean concatenation. Strangely enough, I can connect with a public mobile subscriber who is not in Mexico and is back in Canada by calling 001<area code><7 digit number> (no +) but once they are in Mexico I have to add the + back in (00+1<area code><7 digit number>)
01-14-2025 10:23 AM
Both subscribers While in Mex have to select proper provider as per PM instructions.
01-14-2025 10:18 AM - edited 01-14-2025 10:18 AM
if you are calling a Canadian number , try to simply call by 1+area code+phone number
also, try calling 00+1+ared code+phone number
people have success using one of the 2 ways
