04-07-2022
03:09 AM
04-07-2022
05:44 AM
computergeek541
I bought a pre owned phone during the spring sale. (March31.2022) The promotion was $50 off the iPhone XR and a $20 credit toward next month bill. I do not see credit on my account. Unsure of how I redeem the $20 credit as I was given no instruction and assumed it would be automatically added to my account. I received the phone by mail today.
04-30-2022 05:05 AM - edited 04-30-2022 05:08 AM
The credit was applied yesterday @darlicious posted about it.
04-07-2022 04:36 PM
You probably wanted to give the solution to @JK8 . You can change the solution by going to the little arrow on the right of your post and then choose @JK8 's post.
To pre-verify your account in your private messages only include your full name, address, email, phone # and 4 digit acct pin #
04-07-2022 04:16 PM
Thank you so much! I couldn’t find the info anywhere, but I did use the email associated with my public mobile account so should be all good then! Thanks so much!
04-07-2022 04:53 AM
Going by the past history of when pm applies credits "in the first/last week of the month" I strongly suspect it will be Friday April 29th. I will be looking for my credit to be applied then.
To pre-verify your account include in your private message only your full name, address, email, phone # and 4 digit acct pin #.
04-07-2022 03:53 AM - edited 04-07-2022 03:58 AM
The $20 credit will automatically taken off your May bill so you don't need to do anything.
You can double check if credit is applied to your account by login and check under your current balance amount of $20 on April 30.
If you are under the old Rewards system (activated your SIM before January 25, 2022)...your current balance amount will be $22 credit.
04-07-2022 03:33 AM - edited 04-07-2022 03:36 AM
Have a look at this. It says the credit will be applied last week of April.
Make sure your email used to purchase the phone matches your self service account.
