3 hours ago
2 hours ago
That’s great! Thanks for the info.
2 hours ago
@Dave1001 It will last until you use it all up , no expiry
2 hours ago
Thanks. Is there a time limit to use it in or does it last until it is used up?
2 hours ago
Hey @Dave1001
I have a ton of those over the years. Depending on what plan you have, for example 50GB data bucket, the bonus data will start once you hit 50GB. Now someone here will have to remind me as I think I'm correct but eh, it's the weekend so.... if you have a, for example, a 50GB data plan with unlimited data at throttled 512kbps speeds, I believe the bonus data will keep you going at full speeds and not throttled until used. Someone can correct me if I'm wrong.
3 hours ago
@Dave1001 They will automatically kick in once you have used up your regular plan data
