10-16-2023 08:22 AM
I’m looking to upgrade from 25 month 1gb, are the current offers worth it or should l wait, for a better one, also I’m with old reward system which want to keep, will upgrading still honour it. Thanks
10-16-2023 10:45 AM
@Fdrcamb , shop for a plan that meets the needs first and then look at pricing. It is very evident that bigger data bucket plans have the better pricing per GB data. Big gig plans are not always needed. If you are content with the current plan, why change? If you willing to pay a little more for more data, the $102/60GB/90 day plan is the closest in pricing. For $9 more per 30 day cycle, you will get a whole lot more data.
10-16-2023 10:20 AM - edited 10-16-2023 10:26 AM
you can change plans every month if you wish. I'd suggest you find a plan that you think fits your lifestyle...test drive it....then upgrade or downgrade to any currently offered plan. If you travel to US frequently...there's even a plan for use in Canada AND US.
You won't lose your legacy Rewards...unless you voluntarily opt for Points instead. **HINT... don't ever opt for Points.
10-16-2023 10:18 AM
Cell phone deals change almost every month so you can change your plan now and if there is a better deal in the future…you can change it then (BF, BD or Christmas).
10-16-2023 09:42 AM
HI @Fdrcamb
Black Friday is coming in couple weeks, then Boxing day. Last year Black Friday had lots of great deals with different carriers and PM had no choice but follow, so, keep an eye on that
10-16-2023 08:31 AM
similar to others, I would recommend switching on the next renewal to the plan you desire, and if in future, there are any better offerings, you can always do the same again.
There’s no limit to how many times you can switch plans when better options arise.
Just make sure to always choose to switch the plan on the next renewal and do not ever switch to public points unless you want less value for your money
10-16-2023 08:25 AM - edited 10-16-2023 10:26 AM
first, you won't got changed to the new rewards system with plan change, so, no worries no that
And, for the plans, it's hard to say, PM has been bringing out many new and good plans this year, so, we never know if more new and better ones will be coming. But you can always change to another plan if you see a better one
Just a reminder, use Change on Renewal option if you don't need the new plan immediately
10-16-2023 08:25 AM
Well, if you wait there is no guarantee that the offers will get better. The current plans are still the best out of all the pre-paid service providers. And your rewards system will not change if you change plans.
