09-20-2024 11:09 AM
09-23-2024 10:31 AM
@gurjitc, I would definitely contact a CS agent (if you haven't already done so) to get this fixed as quickly as possible, sounds like something on their end. To open a ticket through the Chatbot:
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
09-23-2024 10:28 AM
i am unable to call others as well.
09-23-2024 10:25 AM - edited 09-23-2024 10:25 AM
i have an iphone 12. definitely not a phone issue because i have been with public since i had this phone. 3G does not work either
09-20-2024 11:18 AM
@gurjitc are you able to call out? Are you able to call your cell number from another phone (not the same person that is getting the error message already), this could help confirm if the issue is on their end or on yours
09-20-2024 11:15 AM
hi @gurjitc it would be helpful for you to provide us more info to properly help you with your issue
it suspect it is a incompatible phone issue. what phone you have?
try changing to 3G network on your phone's network mode and see if it helps
please report us back
09-20-2024 11:12 AM
@gurjitc Try rebooting the phone if you haven’t already see if that helps at all and be sure to dial 1 infront if the contact . If still no dice
