11-05-2022 08:51 PM - edited 11-05-2022 08:52 PM
It says it's "4G" speeds, right? But I did a speedtest from speed.cloudflare.com and it never really got over 4 Mb/s download rate.
I compared my old $40/5GB at 3G plan:
to the new $40/15GB "4G" plan:
Same location, same phone (iPhone 14 Plus).
Seems like the new plan is also throttled.
Anyone else do a speedtest on the new 15GB plan?
11-08-2022 11:35 AM
For me it's been a week since switching and I noticed that after the first 5Gb it got really slow and especially during the hours of 3am-9am...during peak hours or seems to be fast...
11-07-2022 12:47 AM
@mig39 wrote:Those speedtests were taken 2 days before my plan switched. I took the screenshots so I could compare after the switchover.
You can see in the first screenshot that it actually starts with an upload speed around 6-7 Mb/s, but it is quickly throttled down to 3 or 4 Mb/s. If you've ever programmed a limiter or queue on a router, you'll recognize that's how this kind of graphic usually goes. At least that's been my experience on Cisco firewalls, as well as pfsense. I'm sure it's the same principal on telco routers. They sort of have to have an "average" rate to compare to, and before that average goes above the trigger point, it doesn't really see it as faster than that trigger point... if that makes sense.
Think of it it this way -- if you want to limit the rate to 3Mb/s, then you need to record at least a second or two of traffic to determine that there's more than 3Mbits going through in a second, right?
Don't think of it as a speed, but rather a rate -- how many bits can pass through in a second, on average.
Of course, I could be talking out of my ass 🙂 since I have no idea how they program their routers.
Are you saying that the number shown in the screenshot are the peaks? Every other website that I have used to test speeds displays the average.
11-07-2022 12:10 AM
Thanks for the update. Indeed it was just a matter time and when the plan was actually updated in your account vs midnight eastern when your 30 day plan renewed.
11-06-2022 05:40 PM
11-06-2022 05:15 PM
@mig39 wrote:Right on the money 🙂
Here's my speedtest, 3 days after switching over. So yeah, anyone reading this in the future, the best thing to do is just wait 🙂
That's interesting. Was that in the same place? I really do think that there was a network issue because your previous tests give indication that this wasn't the result of the normal 48 hour delay for change of speed. The 3Mbps 3g plans wouldn't have been close to being able to providing more than 6Mbps upload speeds.
11-06-2022 02:17 PM
11-06-2022 01:09 AM
I have been on 4g for over
a month now and speeds are good for me.
11-06-2022 01:00 AM
@JL9 wrote:@mig39 Please keep us updated with the next speed test, bc I will be switching to the 15Gb plan in the middle of the month and it would be nice to see an improvement lol
The best you're going to see on this plan is about 100Mbps downloads and about 10Mbps uploads. Yes, these speeds are possible but it depends largely on the network and available capacity of the network in each specification testing location.
11-06-2022 01:58 AM
@mig39 wrote:It says it's "4G" speeds, right? But I did a speedtest from speed.cloudflare.com and it never really got over 4 Mb/s download rate.
Neither of those speed tests from when you were on either the 3g or 4g plan are thottled. Unfortunately, this is probably as good of a speed you get unless you run the test again in a differetnt location.
11-06-2022 01:57 AM - edited 11-06-2022 01:59 AM
my download speed is anywhere from 7mb-90mb. if the device is connecting to LTE not LTE+ the speed is around 7mb
I'm not too sure what's going on with the upload speed. but it seems PM is throttle it with these new 4g plans
11-05-2022 11:40 PM
11-05-2022 09:19 PM
You may have the opposite issue with it being on a new network it hasn't throttled yet?
This thread may help as it gives a speedtest from a month ago....82mbps. And a case of the 4G LTE full download speed having a glitch. So if your data speed doesn't improve by tomorrow you should contact customer support. Also consider the fact that your plan didn't change until payment was taken.....so rather than midnight eastern when your data counter resets your plan probably didn't update and change until sometime between 6am and noon eastern.
https://productioncommunity.publicmobile.ca/t5/Get-Support/4G-speeds-issue/m-p/886826
11-05-2022 09:12 PM
As a comparison, here's a speedtest from the same phone, same location, but using a European e-sim (Orange France) that's supposed to offer "3G" speeds when roaming in Canada. It's roaming on Telus, so same tower, but using the 5G antenna:
That was only 2 seconds or so of testing before I chickened out and force-quit Safari 🙂 I wonder how much data that used! Anyway, it's *supposed* to be throttled to 3G speeds, but I think it would just keep climbing. And 5G is more sensitive to distance, I think, so if I were closer I'm sure it would be faster.
The same SIM averages around 1Mb/s when it roams on Rogers.
I
11-05-2022 09:06 PM
Oh I have plenty of data on the account....21GB but I still don't want to waste 400mb on a speedtest.
There are "lighter" speed tests but I don't trust their results because when compared to others their results are much lower speeds. You can perform a speed test and cut off a few seconds into the test to get a general idea of data speed with it costing a quarter or less of data used for a full test.
11-05-2022 09:00 PM
Yes, that's always a concern. I wonder if there's a decent speedtest site out there that doesn't use too much data?
11-05-2022 08:59 PM
@darlicious wait 25 days, maybe another 2GB coming 🙂
11-05-2022 08:59 PM
I literally did a reboot, thinking the same thing 🙂
I tested in the same area, to be consistent. But I'll try again from right under a Telus tower tomorrow 🙂
But I just recently switched, so maybe it hasn't updated to the router that does the throttling yet.
11-05-2022 08:59 PM
I have the unlucky $13 plan with full speed 4G LTE data but I'm reluctant to do a speed test and waste my add on data.....there's no plan data to play with.
11-05-2022 08:57 PM
@mig39 before you test next time, try a reboot
Also, test in different area, not just your home or your work, just in case it is some local network issue.
11-05-2022 08:56 PM - edited 11-05-2022 08:57 PM
Ah ok, it's been about 48 hours already, but I'll wait another 24 and test again.
Maybe with all the craziness and downtime, the process is delayed.
Anyone else do a speedtest they can share from the new $40/15GB 4G plan, though? That was the original question 🙂
11-05-2022 08:56 PM
Wow....you were getting 4.74mbps on a "3G" plan? I'm lucky if I can get 2.5mbps on average.
11-05-2022 08:53 PM - edited 11-05-2022 08:54 PM
When did your plan change? It takes up to 48 hours for your data speed to unthrotte.
11-05-2022 08:53 PM
