Activation issue
xiuli
I received the SIM card, but not able to activate it because I can’t receive the code via text message, please assist asap or refund me.
my number is ##########
12 REPLIES 12
@xiuli wrote:
Hello, still haven’t heard back from the CS agent, can you follow up? Thanks
Customer support agents won't respond here. You'll receive a respond through private messaging.  Also, none of the respondents here are customer support agents.
HI @xiuli
i am just customer like youv
did you check the Community inbox? Envelope icon on top right of this page
or message them once more
xiuli
HI @xiuli agent will reply, usually in an hour or maybe two hours.  Just check your Community inbox for their reply
They will first ask you couple verification questions first, then will go and help.  Couple message exchanges and issue will be resolved
xiuli
I already did, but I don’t think there is anyone  is taking my question
HI @xiuli
yes, please submit ticket with CS agent.  They can add the sim card number back for you quickly
xiuli
Still not working , can’t received the code
HI @xiuli you already paid, so you need to continue with your current process
download the app and try
if fails, then PM agent can help, please submit a ticket with them here:
xiuli
Can you reset my activation process, so I can try to start from the beginning again and see if this time it will work?
xiuli
through app. It asks me to input a code from an email - done, then ask me to input a code from text message, not able to receive it. Can you assist this issue. I’m super frastrating now
Dunkman
@xiuli
Did you first activate SIM via website or PM app?
If via website, you will need to finish activation via the app.  Ie. download app and finish the activation process.
HI @xiuli
try click "didn't receive code?" and see if send email is an option there
if not, submit ticket with CS agent and they can add it for you
