Account was suspended even on AutoPay
05-02-2022 12:30 PM
My daughter account was suspended. She is on AutoPay. She can't use the phone right now. It's the second month in a row that it happens.
Please so something
My Account
Payment
Service
05-03-2022 03:56 PM
I reactivated with autopay after suspension even though my credit card was fine. Still set for autopay but only one of my lines were reactivated!
05-02-2022 01:19 PM
No, the card is OK
05-02-2022 01:16 PM
So the registered card works. Wouldn't one think that any corporation would make it as bulletproof as possible to take your money? Yes a fault could be at the customers end. But this card works. Autopay should work. If this is a Visa Debit did you have money in the account at renewal time? Was the registered card near it's limit at renewal time?
05-02-2022 01:12 PM - edited 05-02-2022 01:20 PM
@motanu wrote:The plan was suspended, phone not working. I did choose Reactivate, went to payment screen and followed the instructions from the other link that Meow gave me. As I said, the screen showed 0 Amount Due and $15 balance, I chose Other and entered $10. The plan was reactivated and phone is working now.
I am on $25 plan
@motanu Glad it working now.!!
05-02-2022 01:10 PM
I am on $25 plan
05-02-2022 12:56 PM
@motanu wrote:It says: "Automatic Payments is active on this account". It said that even before payment, because I payed manually now, again. However the payment screen indicated 0 as Amount Due. I used the Other Amount option and payed the difference that I calculated myself
@motanu just wan to confirm, your account is still suspended and you try to reactivate?
If so, then what you try to do was right. Use the option "Other (Enter the desired payment amoiunt)" and manually enter the outstanding amount
Curious, what kind of plan you have ? and what amount you try to manually pay?
(if you are on $10 plan, please note that the price is now changed to $13)
05-02-2022 12:52 PM
OK, thanks
05-02-2022 12:51 PM
05-02-2022 12:49 PM
Are you able to make manual payments using the registered card? Try adding a $1 to test it. If it works then add more to reactivate. No you shouldn't have to do this every time.
05-02-2022 12:42 PM
05-02-2022 12:42 PM
Hopefully not although autopay seems to have been acting up recently. To avoid these headaches altogether, you can manually add the funds needed to cover the renewal a day or 2 before, and you shouldn't have to deal with this again. I know it is a little bit of work, but it will get rid of any chance for an autopay failure causing you to scramble.
05-02-2022 12:40 PM
Thanks but I already did this last month. Do I have to do it every month now?
05-02-2022 12:35 PM
Similar question posted 18 min ago. https://productioncommunity.publicmobile.ca/t5/Get-Support/Reactivating-suspended-account-with-autop...
Follow instructions provided by @softech .
You have to pay manually selecting either 'Select an amount' or 'Amount due'
