Account showing the wrong plan than what I am paying for
sarah2b
 My current plan is 3 gigs for $25, and in my payment history it shows: 3GB at 3G Speed
In my Plan Usage section it shows:
Data Usage
1024 MB at 3G Speed
Has this happened to anyone?
11 REPLIES 11
Milk
Are you sure that your plan is not $30 with 3 GB data?
@sarah2b - well this weird. IF you paid $25 for 3G, please let me know, that'd be GREAT!
But I suspect just a refresh/cache...Public Mobile issue in this case.
What does it say your data balance is when you call 611? This will include that 1024 MB addon balance also.
@LitlLdy wrote:
@sarah2b , I see what you mean! That doesn’t look right at all! Try @softech suggestion & let is know if it looks correct that way.
There’s definitely some issues in the system!
It does look strange. However, I will say that if the system is allowing 3GB of plan usage, this is mistake and the customer is getting more than is being paid for.  The $25 plan doesn't include 3GB.
DDM69
@sarah2b
You are right.  Something is off here.  Let us know what you find out.
@sarah2b did you recently change plan from a $30/3GB or $35/3GB to the $25 plan?
please try to login My Account again using Incognito mode, let see if it. shows 1GB then
@sarah2b
yes, the correct $25 plan at 3G speed is showing there
It comes with only 1GB , you probably got the 3G speed misrewd at 3Gb data
sarah2b
The photo is what my account shows my current plan is, which doesn't align with how much data is shown in the plan usage
sarah2b
Sorry, but there has never been a $25 3GB plan.  The $25 plan only includes 1GB.
@sarah2b  Try this first
simply try refreshing the page when logged in
