05-01-2022 11:17 AM
05-01-2022 11:39 AM
HI @Guptarachana If data is more important than receiving calls and text on your PM number, you can instead buy local US Data from there, then use VoIP app , TextNow, Fongo, for voice and text. Just want to provide you a cheaper alternatives
05-01-2022 11:31 AM
@Guptarachana wrote:I am going to United States and would need to activate my roaming plan urgently
@Guptarachana Open a ticket now, PM Support usually reply within an hour or two
I imagine you do not remember your 4 digits PIN, if you do , you can actually load fund via *611 and then buy Roaming via *611 as well
If you do not remember the 4 digits PIN, since you are resetting your My Account login, you can ask them to reset the 4 digits PIN as well
05-01-2022 11:30 AM
If you are on autopay, dial 611 on your phone and you can purchase add ons. You will need to know your PIN.
https://productioncommunity.publicmobile.ca/t5/Self-Serve/611-IVR-Menu-System/m-p/289352
05-01-2022 11:28 AM
05-01-2022 11:21 AM - edited 05-01-2022 11:21 AM
@Guptarachana Wait a full hour and try again. It could be just a temporary lock
If still fail, try to use the Forgot Password link there (https://selfserve.publicmobile.ca/forgot-password/) . Enter the correct email address, answer the security question and you can then self reset the password
If still fail, you might want to open a ticket with PM Support and have them to sort it out for you:
1. For faster response (2-48 hours), Click on the bubble in the lower right to request CS Agent assistance, or use this direct link: https://publicmobile.ca/chatbot.
**Start with typing "Forgot Login Information", click "Contact Us", click "Click here to submit a ticket".
2. Or Send a private message to the CS Agent here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
