Account help pkzzz
Dee25
How do I finish setting up my account when I want to use prepaid voucher to add funds? Not a credit card. I cant get any help where like this it won’t allow me passed the add payment method.
hairbag1
@Dee25
get a prepaid visa/mastercard at Canada Post, 7-11 or other retail outlet. Use that card to activate your new Public Mobile account. Then you can disable SUBSCRIBED to be able to use vouchers for future renewals.
Dunkman
@Dee25
Public mobile management has confirmed that new customers are not able to activate new accounts with payment vouchers.  Do you have a Visa debit or Mastcard debit card to use?
Otherwise, you will need to purchase a prepaid credit card and use that to activate new account.  Then you could purchase vouchers afterwards to pay for the following months.
Dee25
I have one just can’t access funds atm
eddieO
@Dee25 I'm pretty sure you will need a credit card to get the account setup, after that you can pay with vouchers. You can try reaching out to a customer support agent to see if there is anything they can do to setup up without a credit card.
try sending a private message to:
@Dee25  You need crest card to first create and activate account , after that you can use vouchers to pay the bill . So once you have created account with credit card you can load the funds into the account using the voucher after that
kremie
I would recommend adding a credit card and then adding funds via a voucher if you don't want anything billed to the card. If you don't have a credit card, then that's a whole other issue.
