06-01-2025 01:13 PM
06-07-2025 01:07 AM
If you somehow changed the conditional call forwards that now prevent "busy" calls to your own number to forward to voicemail, you can try resetting them all by dialing ##004#. Then try calling your own number from your own phone again to see if it made any difference...
06-01-2025 01:48 PM
hi @Wayneasmith try reboot phone and Reset Network Settings first
if still does not work, try the different numbers here and see which one works a d program it as your VM access number
if still does not work, ask PM support agent to help
please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
