Esim replacement
Golfkart
Ordered 2 esims. First esim I declined to activate on current phone. The second esim it didn't prompt me if I want to activate on current phone. Instead it just added esim. Is there a way to transfer this esim to a different phone? I don't want to pay $5 for a bar code if you get my drift.
James61722
I ended up a subscribing to the services yesterday and installed in as there is no store that is available around my area that sells physical SIM cards unless 8 hours away I'm doing so my son accidentally deleted my phone and all contents so I ended up losing my esim I reinstalled the applications and everything and gave him my older tablet to play with any use on doing so do I have to purchase the esim again for $5
@Golfkart as long you paid it once with that accounts, PM shouldn't charge you again.  If they did, open ticket with PM support and ask them for reimbursement :
1. Open ticket via Chatbot (need access to My Account): At https://widget.telus.tiia.ai/publicmobile/publicmobile.html
    Start by typing "Submit a ticket", then click "Contact Us", then "Other", then "Log In", finally click "Click here to submit a ticket ↗
Golfkart
Ummm it actually charged me the $5
@Golfkart
you don't have to pay $5 again after you paid for the first one
While eSIM cannot be moved, you can get a replacement for FREE
To rebuy new eSIM for FREE, first, download the app on your new phone.  Click Account from the bottom, then click Purchase SIM Card and select eSIM
Once it confirms your phone is eSIM compatible, click Pay $  and Install (the system will check and apply a $5 credit to bring the total price back to $0 at checkout), and follow the prompt to complete and purchase and install eSIM on your device
https://www.publicmobile.ca/en/on/get-help/articles/get-a-sim-card
Existing eSIM users at Public Mobile who need a replacement can do so at no extra cost. When you request a new eSIM through the usual process, we automatically identify you as an existing eSIM user and waive the replacement fee. See below for steps on how to get your new eSIM.
