Account change
nitzdut82
Hi
I requested an account change yesterday but it didn't happen why?
My bill circle is Dec 27 which is today
10 REPLIES 10
Hold it @nitzdut82
You see plan amount charged on your payment card as the "old" amount, but the self-serve site shows the new plan?
Clarify please?
@nitzdut82 wrote:
Ya I see change now yhanks
@nitzdut82
I guess Incognito mode works  🙂
nitzdut82
@nitzdut82 wrote:
Ya I see on my credit cars it's charged with old amount
@nitzdut82  So, it is not correct, right?  You made a plan change and it supposed to charge you the new plan amount
if it is still day 1 of your new cycle , do not wait , just open a ticket with PM Support and they can still do something to make the plan change for you  if it is day 1.
So, open a ticket with PM support using chatbot and tell them you did schedule a plan change and it didn't happen:
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
nitzdut82
hairbag1
@nitzdut82 Login to My Account using Incognito mode and see if you see the correct plan
Also, check Payment history to see if PM charged you the new plan price earlier today?
Check  also what is it showing for the current plan cycle.
@nitzdut82 @Your can also try refreshing page when logged in , and or clear web browser cache / cookies
@nitzdut82 @You may need help from a agent
To Contact CSA-agent; there are 2 methods:
Ticket has to be opened through chatbot - https://widget.telus.tiia.ai/publicmobile/publicmobile.html
If ticketing does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking (Ctrl+)Here
