08-04-2023 11:43 AM
Can't confirm for full access. Code never is delivered to my text #
08-04-2023 12:00 PM
you just cannot login because of the 2FA code? or you have problem with the service and/or activation:?
Please submit a ticket with agent for help:
08-04-2023 11:54 AM
No there is no option for email when we click resend code
08-04-2023 11:52 AM
@Ckunopaski Try tapping resend . A few times you should get option to send code to email instead . If no luck please submit ticket to support o help you re gain access
private message To CS_Agents click
VVVVV Link below VVVVV
08-04-2023 11:49 AM
@Ckunopaski - or if you enter the code incorrectly a few times, do you then get the email option?
@Chalupa_Batman what do you mean about screenshots?
08-04-2023 11:45 AM
08-04-2023 11:45 AM
you just activated a line today? or you have been PM subscribers for sometime?
Try
On the screen it is expecting you to enter the code, click Resend code and then choose Send email
