Subscription
behaviorbuoy
  • Did the Canada-US 40 GB plan at 4G change to 5G data?
behaviorbuoy
Thanks again for your help
Hi @behaviorbuoy
it is now 5G, but you have to make a plan change yourself still, it is treated as a different plan
but make sure you use Change on Renewal
@behaviorbuoy  We are just customers like you . If you changed plans immediately and not in renewal you will be charged that full amount right away and start a new 30 day cycle . pM is no refunds but if you just did this you can try and submit ticket with support to see if they can reverse it for you
private message   To CS_Agents click
behaviorbuoy
Thanks for reply. I just changed my subscription from 4G to 5G. Can I get that reversed since it changed anyways?
DennyCrane
Yes, yesterday it changed. But if you're already in the 4G version of it you need to change plans to the new version.
@behaviorbuoy  Yes it sure did . If your on then 4G  version of it be sure to change plan for next renewal so you don’t lose money on your current cycle
