02-09-2023 02:01 PM - last edited on 02-09-2023 02:06 PM by computergeek541
02-09-2023 02:40 PM - edited 02-09-2023 02:41 PM
@hTideGnow- I know. And what makes it more interesting is that they got through. But it's not official (adding - except the 300). Like you said, talk fast. 🙂
02-09-2023 02:22 PM
When all else fails, try a device restart... Just in case.
02-09-2023 02:21 PM
@hTideGnow Yeah, there has been quite a few posts mentioning that more countries than what's on the list were available to call and some customers did try calling countries not on the official list with success.
@binh514123 Your call should definitely not hang after 5 minutes. First just try rebooting or toggling airplane mode on/off. Did you check with the person you are calling if there's an issue on their phone, just in case?
02-09-2023 02:10 PM
HI @binh514123 you have to talk fast then 🤣
did you try different numbers and all same?
And does it hung up right at 5 mins? or roughty?
@dust2dust the Holiday Long Distance bonus could include more countries than listed. I remember there were posts talked about it.
02-09-2023 02:07 PM
500? Or 300? The 500 freebie doesn't include Australia.
02-09-2023 02:07 PM
@binh514123 does it do this every time or just last couple times in the same hour ? Could be weather related possibly
