I get a message, " no available minutes "
Jeepio
for the third time in a row, my public mobile phone let not make me calls. I says : no avaialable minutes left.
I tried restarting my iphone, I tried  putting sim card out and back in. noresolve
slusagm
you cannot call any number at all? if you have not try other number, try it.  And try calling both way:
1. with a 1 in front of the 10 digits
2. without the 1 in front
TheSterlinger
@Jeepio  did you sign into your account to check the account status? Or call *611 to hear the status?
Chalupa_Batman
I would suggest you do a network reset on the phone and then reboot. If the problem keeps continuing, file a complaint with customer service and they may reset your network on their end as well.
