43$ Canada-us plan
07-09-2023 01:06 PM
Does this mean I can call and use data in the USA ? It’s says Canada-us data and it says Canada-us calling
Plans
10-18-2023 07:49 PM
You were most likely using the 2G GSM network from T-Mobile for those calls. That's a version of my phone and my phone does not have volte.
10-18-2023 07:45 PM
I have a Samsung Galaxy A31
https://m.gsmarena.com/samsung_galaxy_a31-10149.php
the model is SM-A315G/DSL. It is a midrange phone.
10-18-2023 07:17 PM
HI @Prosperious2 / @MIchaelGamliel9
what phones and models do you have?
10-18-2023 07:13 PM
I was in Las Vegas Oct 1-7 and I was able to use both Data and calls without issue. I was connected to T-Mobile if I recall correctly.
10-11-2023 12:34 PM
I was in Vermont last night fully connected to AT&T with data. Have this package and data worked but calls failed never worked. Roaming was on and lte was on. Burlington Vermont to be specific.
07-14-2023 04:37 PM - edited 07-14-2023 04:39 PM
You can keep your legacy rewards program when you do a plan switch.
07-14-2023 04:34 PM
If I switch to this plan, will I be able to keep my current Rewards or will it swith to "Public Points" ?
07-09-2023 10:38 PM
I want this plan on BC sooooo bad
07-09-2023 01:19 PM
@MIchaelGamliel9 It sure is . Call to and from Canada and the US in both countries . Great plan !:)
07-09-2023 01:14 PM - edited 07-09-2023 01:20 PM
the Canada-US plans are those Snowbird plans for people go to US a lot and use the service without paying extra for roaming. But to subscribe, you need a credit card linked to Quebec address. If youbare in Quebec, this is really a wonderful plan
07-09-2023 01:08 PM
@MIchaelGamliel9 yes it is. You can use the service in US
But it is a plan for Quebec subscribers only
