07-25-2025
03:19 PM
07-25-2025
06:49 PM
computergeek541
I am trying to set up an account for my business the account name is different then the credit card name. How do I purchase a plan? I also can't seem to go back and change the name
07-25-2025 07:00 PM - edited 07-25-2025 07:07 PM
The account name does not have to match the credit card name. I have opened accounts in different family member's name and used my credit card to pay for it.
Also, it is possible to change the account name in "Account", "Manage Profile" at any time. I have changed the account name from a personal name to a company name and back again in the past. You just have to fit the company name in the First Name and Last Name boxes (for example "ABC Food" "Enterprises Ltd.".
You can always change the credit card at any time.
IMO, There is a greater risk that PM may not let you use the same email address a second time even if you close the first account.
07-25-2025 06:50 PM - edited 07-25-2025 06:52 PM
@Aiden1234 wrote:I am trying to set up an account for my business the account name is different then the credit card name. How do I purchase a plan? I also can't seem to go back and change the name
Public Mobile doesn't compare the name on the Public Mobile account to the name of the credit card holder. Those don't need to match.
@slusagm wrote:PM is prepaid, so, account name is not that important, but should match the name on the credit card
It makes no difference at all. Name is not part of the payment system security checks.
07-25-2025 03:54 PM
likely yes, but you might have to wait a day or two before you can reuse the same email address. Ask PM using the link I provided above
but honest, it is easier and quicker to just use another email address for a new account
07-25-2025 03:48 PM
Is there a way to delete the account then and I can start over? I don't want to use a different email.
07-25-2025 03:25 PM
can you create a new account using a different email address and start again using the name on the credit card as the name on this PM account?
or you can ask PM and see if they can sort it out. Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
