8m ago
We don’t know what email was used to open the account and a 4 digit PIN was never set up. There is no means to call customer service without a PIN and no means to add a new credit card to enable payment without a PIN (by phone) or email address online. Impossible to get a human. I was directed to this community page to start a ticket.
5m ago
hi @Cam71
did you try the Forgot Login link on the login page? it will send you an email to the email address used to login, the you can use Forgot Password link to setup new password
if if that does not work, ask PM support agent to help. Submit an Expert Messaging ticket (Please use the same Community login you are using now. If you get stuck with the login or 2FA code, then use a different email address to create another Community account and submit the ticket with this new account): https://expert-messaging.publicmobile.ca/guest/chat/
At the Chat, type "Submit Ticket", then type "Connect Agent", and type "Connect Agent" again. Then login to open ticket
Support agent will reply within 2 to 4 hours. You will be notified via SMS/email or monitor here:
Remember: Support hours of operation: 9 AM to 10 PM ET
