07-28-2023 06:05 PM
Good afternoon
Looking into this plan. When I look at the main Public mobile page I see the notation for "the fine print" labeled as '++'. This fine print indicates that the plan is applicable for use in the US and Canada - texting, calling and data.
However when I log into my account and select 'Change Subscription' there is a notation for the Fine print '3'
I assume this is just and error and the roaming is indeed a part of the plan as indicated.
Has anyone else noticed this? Should I be concerned if I make the switch to this plan?
Thanks
07-28-2023 06:11 PM
Thank you all. I did look in the community prior to asking the question but didn't see anything.
Appreciate the quick feedback.
07-28-2023 06:08 PM
@Just_a_guy yes, this plan include US roaming data and voice
To subscribe, just login My Account, click Change Subscription on the top right of the Overview page and pick the right plan, follow the steps. Make sure you click Change in Renewal if you don't want PM to charge you now
07-28-2023 06:08 PM
@Just_a_guy Yes there a few posts about this already . But it’s definitely US Roaming included . Much like the $15 plan not mentioning unlimited incoming calls and just 100 out going calls .
07-28-2023 06:07 PM
Yes it has been commented on before. Don't be concerned. It's a roaming plan.
