07-28-2023 05:56 PM
07-28-2023 06:11 PM
It is totally ridiculous. I kind of think that we should be able to re-buy it when it gets to 0/15 and not before. It's been like this for as long as I know though.
May I suggest switching to the new roaming plan. Might be cheaper even for just your remaining couple weeks. And you get 40gb of data to use.
But not if you have a plan that you like and is no longer available.
07-28-2023 06:10 PM
@benzorro57 no stuck, you just need to message support to get that fixed, usually they will reply pretty quick
message them here
07-28-2023 06:08 PM
This is ridiculous. I should be able to buy it when ever. If i'm in the US for a month I'm stuck till it disappears.
07-28-2023 06:04 PM
Another option is to buy the other bundle or another data bucket. This has been a system deficiency for seemingly ever around here.
07-28-2023 06:02 PM
@benzorro57 Please submit ticket with support
private message To CS_Agents click
VVVVV Link below VVVVV
07-28-2023 06:02 PM
> It worked and expired and bought more
@benzorro57 was the earlier one expired less than 24 hours? if so, you need support to help to re-buy the exact same one. please message them here
07-28-2023 06:02 PM
how to i talk to public mobile and get them to fix this
07-28-2023 06:01 PM
This is a re-buy problem then. If you still see the 0/15 for the add-ons then you need to either wait for it to disappear or ask support to re-buy it for you.
07-28-2023 06:01 PM
@benzorro57 So this is re buy . You need to wait 24 hours after first one ends . But support can help apply it back to back for you
07-28-2023 06:01 PM
you are in US now?
Critical part to US roaming depends on T-Mobile coverage and whether you can connect to T-Mobile network or not
If the phone is not connecting to T-Mobile, change the Network Connection from Automatic to Manual and select T-Mobile
If your issue is with data, make sure your Roaming Mobile data is enabled and your have disabled your mobile data limter
If your issue is with voice, make sure VoLTE is enabled on the device setting. And if it does not work, try to change the Preferred Network Type or Network Mode to 2G and see if the calls goes through
Also, you can download VoIP app TextNow as a workaround to make calls and text if you have Wifi or if your roaming has data component and data is working
07-28-2023 06:00 PM
I'm in the US. Profile show that I have paid for both. I believe twice and no data.
07-28-2023 06:00 PM
Did that. It worked and expired and bought more. But now doessn't work My profile see that i have paid.
07-28-2023 05:58 PM
Are you in the US? Are you in Alaska? What roaming did you get, full bundle, partial bundle, just data?
07-28-2023 05:58 PM
@benzorro57 Reboot the phone and make sure your connected to T mobile and that data roaming is on
