10-12-2024 05:22 PM
Mobile data became so slow (almost no internet) as a user in downtown vancouver BC. Is this related to me ending the 90days term after switching to Public? Is it always this slow? (I doubt so but the speed got slow right on the day I paid the monthly fee.
I can't even start internet speed test.
I'm writing this on wifi. My plan is 40GB on 4G, and I barely used 250mb now (as I said the speed got slow on the monthly renewal date which was 3 days ago)
10-22-2025 11:13 PM
I have the same issue with data becoming unusable all of the time and it happens to me no matter where I am in Toronto, Ottawa or Montreal. Just randomly drops to unusable speeds for hours or days.
10-12-2024 07:26 PM
hi @Jsmoo
did you try 3G only or WCDMA only?
10-12-2024 07:20 PM - edited 10-12-2024 07:20 PM
I’m having the same issue in Vancouver. I’ve resetted the network on my phone,
restated my phone and still, the internet is so slow I can’t even load up speed test and it took me about 6 tries to even log into the public mobile app..
10-12-2024 07:00 PM
The PublicMobile/Telus network is screwed for data the last few days in the lower mainland. Some times it works, some times it doesn't. It appears to be an issue with the speed throttling they do as I don't believe unthrottled Telus customers are having the issue. It is not a problem with your phone. I've verified this with many people/accounts/phones near me.
10-12-2024 06:12 PM
hi @F4g91YzT change back to the Lte/4g mode tomorrow and hope it works then
10-12-2024 06:07 PM
Thank you @hTideGnow Now it works!
I changed the settings to connect to GSM/HSPA only on My Samsung Galaxy.
Now I have the internet though a bit slower than expected. Well it's better though than no internet.
10-12-2024 05:27 PM
Check your voice and data setting on 4G/LTE and see if that helps.
10-12-2024 05:27 PM
hi @F4g91YzT there has been major data issue I'm Vancouver since yesterday
try reboot your phone first
if same, the current workaround until issue is fully resolved is to change the network mode to 3G only or WCDMA only
