3g to 4g
dannym5830
Switched 4g 6gb plan last week still not showing  up in my account
7 REPLIES 7
Hi @dannym5830 did you see PM charged you the new plan amount??  Check the Payment History on My Account and your credit card
if that still not right,  open ticket with CS agent:
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
  1. start by typing : Contact CS Agent
  2. then Click "Contact Us"
  3. then Click "Other"
  4. finally Click "Click here to submit a ticket"
dannym5830
Still not showing up
@Meow wrote:
It usually takes 48 hours for 4G Plan to show up after switching.
This above isn't right.  As the custoemer was asking about there be no indication of the new plan in the Selve Serve   account, please reazlie that the 48 hours is only for the new speed to take effect.  It's unrelated to the plan details shown in the account.
HI @dannym5830   so, you didn't even see it showing as your current plan?
If you go back to plan change page, did it tell you you have a scheduled plan change coming up soon?
And check if PM charged your new plan amount already last week
hairbag1
It's a long-shot...but try cycling phone OFF then ON again.
Also, try removing sim for a minute, then replace.
If it's been several days since you upgraded to the new 4g plan...check with CSA for their assistance.
Give them as much account info as you can eg.phone number, acct number, etc.
darlicious
@dannym5830
Did you schedule a change plan in next renewal? Has that occurred yet? Or did you change your plan immediately?
Meow
