yesterday
- last edited
yesterday
computergeek541
So I have been with P m forever. Got a 30? Plan 3 g. Don’t need anything else. But. I am watching horse racing on live stream on line. Freezes a bit. If I upgrade a bit would it make a difference ? Thanks
yesterday
I think what some here are missing are there are several factors to your live streaming on your phone. Signal strength being one of them. Sometimes one bar or two are not enough. It also depends on your phone. What app you may be using to live stream. Is there enough space to store the temporary data of the live stream to continue at a smooth play without interruption or freezing. So many factors.
Upgrading a plan isn't always necessary. It's the phone that is more important. Upgrading to a better phone can make a big difference.
yesterday - last edited yesterday
It will probably help.
Your 3G plan actually is a 3G speed plan. While you are free to use the 4G/LTE or 5G network with your 3G plan, your 3G plan limits your data download at 3Mbps , which means your streaming speed is capped at 3Mbps. If you upgrade to the 4G plan, your download limit will increase to 100Mbps; or you can choose a 5G plan with maximum download speed at 200Mbps
