01-13-2023 08:38 AM
I changed my plan from 3G to 4G in December 2022 and it hasn't changed why is this?
01-13-2023 11:58 AM
I think that you may notice a speed improvement if you go to your phone setting --> cellular data options ---> enable 3G. Yes that would disable LTE( that is throttled down) but for some reason the download speed will improve.
01-13-2023 11:53 AM
For day to day use that includes occasionally using GPS maps, I can't notice any difference between 3G and 4G. Perhaps a difference would be noticed when streaming movies but then it would eat up data.
01-13-2023 10:17 AM
thanks, 3 is not fast lol, but pay only 15
01-13-2023 10:01 AM
@yackinlyn the 3G plan you got is just 3G SPEED plan. We all can use the 4G LTE network, just a matter of the speed
with 3G SPEED plan like the $15 plan, you still access 4G/LTE network but with a capped speed at 3Mpbs
and for voice, whether you are on 3G speed or 4G speed plan, everyone is using 3G network for voice. But we don't need to care about this, as the phone would automatically drops down to 3G when calls are made
01-13-2023 09:58 AM
I only use $15 plan which is 3g,but when I turned on data, the top says LTE 🙂
01-13-2023 09:39 AM
It's been way more than 48 hours it's been over a month.
01-13-2023 09:38 AM
Thanks everyone. I had LTE before I changed my plan so I thought it should show LTE/4G or 4G?? Anyway!
01-13-2023 09:36 AM
@Mir3046 @LTE is what you want
01-13-2023 09:34 AM - edited 01-13-2023 09:35 AM
01-13-2023 09:34 AM
@Mir3046 add to @computergeek541 comment, try your phone at different places and see if you got the new speed
Also, if the phone shows LTE, then it is good, LTE=4G
You might want to download some speed test app to confirm the speed is at 4G/LTE speed
Try this one: https://www.speedtest.net/apps
(Be aware that as many as couple hundred Mb of data will be used for EACH run of the speed test.)
01-13-2023 09:32 AM
Mt only options are LTE or 3G?? If I'm looking in the right place??
01-13-2023 09:24 AM
The same networks are used both for 3g and 4g plans. Please check your device's network type selection setting.
01-13-2023 09:17 AM
The correct plan is showing and I paid for the new plan but my phone is only showing 3G not 4G.
01-13-2023 09:13 AM
Please post a screenshot of your plan details for us (ensuring any private info is masked) after tapping the refresher icon on the landing page.
Also, if you check your payment card, how much was withdrawn from it for the most recent renewal -- the old plan value or the changed plan value?
When you processed the plan change, do you recall if you scheduled it for your next renewal?
If you change from a 3G plan to a 4G plan, you may have to wait 48 hours for the 4G service to become available after your renewal. You may also have to reset your network connections or manually set it to LTE if it may be set to 3G currently.
01-13-2023 09:12 AM
@Mir3046 try one more thing
Login My Account Using Incognito mode and you should see the correct plan showing there
to get to Incognito mode, click on the 3 dots on top right, select New Incognio or New Private window.
01-13-2023 08:57 AM
@Mir3046 @Your welcome , hope you get it sorted out quickly
01-13-2023 08:56 AM
Thanks
01-13-2023 08:52 AM
@Mir3046 @You may have to reach out to support to get it fixed
Getting help from agent
Or get help right here in the community
01-13-2023 08:49 AM
Nope still not working. They don't mind taking the money but don't update the plan...
01-13-2023 08:39 AM
Try again incognito mode/private mode or simply try refreshing the page on the yellow circle while signed in to public mobile
Refresh page. ^^^
