01-12-2025 10:26 PM
I’m going to US next month. I just want to use my phone 7days in US. I’m thinking about to change my subscription to use in US only next month. Then I’m going back to my original subscription. Do you think it’s not issue? I just want to be back my original subscription plan when I’m back to Canada.
please advise me.
Thank you.
a month ago
Thank you very much! I will do add on instead of changing my subscription plan.
01-12-2025 10:39 PM
It completely depends on what your current subscription is. What is your current plan?
01-12-2025 10:30 PM
Hi @NoriT ,
It depends on the prices, lately PM is not allowing to downgrade packages/plans, hence if you make the change there is no commitment that you will be able to return back to your previous package, hence it depends on the price.
If the difference in $ is small , maybe it's time to upgrade and forget, if it's a big difference then use ADD-ON for US.
Hope that helps,
Best.
01-12-2025 10:28 PM
Don't do that. The cheaper plans will be removed from your account once you upgrade.
Either use add-Ons for US trip or start considering porting out, once you return and can't downgrade to your original plan.
