06-13-2023 02:12 PM
I am unable to see that promotion once I sign in into my account. It is showing me default $45/month 15GB+15GB and not 90-day subscription on this plan.
I want to change my subscription before it expires.
Please help.
06-13-2023 10:12 PM
If the promo had been offered in Quebec, I would have definitely taken it! I'm on the $39 /20GB plan. I think I can survive without the extra 10GB. 🙂
06-13-2023 10:08 PM
@EZR Quebec usually have better deals than the rest of Canada. This is one odd time that good offers do not apply for Quebec. But trust me, you will see some much better Quebec only deal soon
I believe you can still get this deal if you are willing to change the phone number to other province if you really want to get the deal.
06-13-2023 10:04 PM
If I change the region it shows, just not in Quebec and this is sad. When you click on offer details. It says:
This offer does not apply to Quebec customers.
06-13-2023 10:00 PM
@EZR- Do you have a Quebec number? Does it let you select the plan in the change plan screen if you choose your region as other than Quebec?
06-13-2023 09:56 PM
Unfortunately, this plan/promo is not available in Quebec. When I select Ontario it shows but not in Quebec 😞
06-13-2023 03:01 PM
Thanks!
06-13-2023 02:56 PM
@tanishqbhatia Try Profile tab and you should see options to edit many things in your account.
06-13-2023 02:53 PM
Anyone knows how to change address?
I can't find it on this new eversafe UI.
06-13-2023 02:51 PM
Yes, I have added a screenshot. Hopefully I get 30GB instead of 20GB for the same amount.
I subscribed to earlier promo ($39 20GB 30-day plan) to Change on renewal but I don't see that promo now either.
06-13-2023 02:47 PM
@tanishqbhatia And you have Ontario number that’s so odd , screen shot confirmation of plan change from support to just in case something goes south on your renewal and it still only goes to the $39 20GB from your current $40 15GB instead of 30GB
06-13-2023 02:45 PM - edited 06-13-2023 02:49 PM
@tanishqbhatia Your screenshot is showing that you've subscribed to the 90 day/$39/30GB plan and it will start on June 20th, so no need to contact support?
edit: adding the $39 price point is the give away that you'll be on the 90 day vs 30 day plan.
edit: okay, I see it says 20GB, very odd. Sorry about misreading it..
06-13-2023 02:43 PM
Upcoming subscription:
Current subscription:
I am unable to see 90-day plan so I have contacted support and messaged them.
Thanks everyone for quick responses.
06-13-2023 02:41 PM - edited 06-13-2023 02:43 PM
@Handy1 Hmm...that's curious because I'm able to see all the plans including the $15 plan (I'm on) when clicking the Change Subscription link, which makes me wonder if the $15 plan is coded differently and hence the reason I'm able to view it..
edit: @Handy1 @dust2dust so are Quebec residents/numbers not eligible for this promo?
06-13-2023 02:37 PM - edited 06-13-2023 02:39 PM
@dabr I can never see the plan that I’m on in my account for option to change to it
Add with out doing the early renewal trick to not get support
06-13-2023 02:36 PM
@tanishqbhatia That's really strange that you're not getting the same options as the rest of us. Maybe try shutting down the computer and rebooting.
06-13-2023 02:35 PM
@tanishqbhatia Well worst case you can get support to apply it for you . Unless as @dust2dust ask you do you have a Quebec number is so your out of luck
Message support directly
06-13-2023 02:34 PM
I have tried that multiple times even used new browser but still don't see it.
06-13-2023 02:34 PM
No, I don't see that plan. Its not showing on new browser session/incognito or app.
06-13-2023 02:33 PM
No, it shows $45/month.
06-13-2023 02:32 PM - edited 06-13-2023 02:32 PM
@Handy1 OP would still be able to see that plan even if on it already on it by selecting Change Subscription link in overview page.
06-13-2023 02:32 PM - edited 06-13-2023 02:33 PM
@tanishqbhatia Go to subscription add on do you see this
If you do you have already selected it for renewal and that’s why you cannnot see it in your my acc
Select the $45 one. It will ask about next renewal or now. Choose next. It will go to a next page. See if it says $44 then. Then if you like choose the 30 or 90 days. See that it says $117 or $44. I just checked on the website change plans and I see the $44. So it's odd that you're not.
Adding - are you in or do you have a Quebec number?
06-13-2023 02:31 PM
@tanishqbhatia Try logging out of your account and then retry either with a new browser or clear cache/cookies and use incognito/private mode again.
I still see the plan available in My Account right now.
06-13-2023 02:31 PM
@tanishqbhatia Only reason I can think you can’t see it is if your already on it or have it set to start in your next renewal
06-13-2023 02:30 PM
Yes tried that already. I don't see the plan once I sign in.
06-13-2023 02:29 PM
@tanishqbhatia Try this just go to website find plan . You will see option to subscribe online tap it . It will then ask you to sign in then do it
06-13-2023 02:28 PM
06-13-2023 02:28 PM
I don't see the promotional plan.
06-13-2023 02:25 PM - edited 06-13-2023 02:27 PM
@tanishqbhatia That’s the wrong plan in your screen shot. Your looking for 30GB for $44 then you get option for $39 90 day
06-13-2023 02:24 PM
@tanishqbhatia You have to select it first and it will give you option for 30 day or 90 day like in @softech @pic
