03-02-2024 12:51 PM
Hi,
I just upgraded my plan 2 weeks ago and migrated to a $34 plan 20 GB and kept the old reward system.
I just saw the $34 plan 50 GB data. When I was trying to switch to the plan in the next bill cycle I read on the disclaimer and I am a little confused whether it will allow me to keep my current reward system.
From what I read on the forum it should, but I wanted to confirm if I was taking the right approach.
Thanks
03-02-2024 01:18 PM
Rewards stay as is.
Some Add-ons might become inactive/obsolete particularly if you currently have data add-on and chose plan with unlimited data. Or if you have US minutes and chose US/Can plan...
03-02-2024 01:02 PM
@DrunkenMonkey Yes you will keep your old rewards no worries I can confirm this I just switched to this plan myself and kept my old rewards
03-02-2024 12:55 PM
@DrunkenMonkey - Your old rewards are going to stay the same.
Your add ons should stay on the account if you got it still after 30 days.
03-02-2024 12:54 PM - edited 03-02-2024 12:56 PM
hi @DrunkenMonkey dont have to worry, that does not mean your rewards discount you are getting now. That is for the special promotion some people see under My Promotions on My Rewards. If you don't have. that section, you are ok. You will still be on the old rewards system
