10-25-2023 02:19 PM
I can’t log into my account as the eversafe is attached to my phone number but I need to change my phone number since the phone number transfer failed and will not work as my old provide account is now deactivated. I need to be able to login so I can get a new number but I can’t login as it wants me to tell them the code it sent to my number which doesn’t work
My Account
03-02-2024 01:02 PM
They definitely need to figure out an alternative for this SMS code to login. People changing over or activating accounts will undoubtedly have issues with sending/receiving messages and phone numbers. Not having support for this and port authorizations is a major oversight. Especially after already verifying via email.
10-25-2023 04:47 PM - edited 10-25-2023 04:47 PM
if you are unable to receive the option to get the code sent to your email, contact customer support
To contact a Customer Support Agent, send a private message to the Customer Support Agents by clicking here
You’ll need to be logged into your Community account for the link to work.
10-25-2023 04:42 PM
I don't get that "Didn't get a code" option instead I just have a resend code option which just sends another code to my number I think which doesn't help me. Is there a different spot I should try to login on?
10-25-2023 02:32 PM
Click on: ‘Didn’t get a code’ and you will get more options.
10-25-2023 02:23 PM
Did you have an email address on file?maybe you can get the code sent there? This is part of the reasons why I don't like businesses such as this where you have no phone number to call and speak to someone 😒
