No service
Dijo
Hello! I've signed up for a plan and ported my number but don't have service. I originally had an esim set up and that didn't work, so I entered a physical sim card number in the app. How do I go about activating this physical sim? Thank you!
Dijo
Thank you for this information. I did switch it in the app. Should my service automatically work after that? I just recently ported and could not activate via esim which is why I tried a physical sim but that isn't working either.
I've tried multiple times to submit a ticket but haven't had luck getting to the part to type out my ticket and submit. I've sent a private message to customer service though. I hope that's ok!
Dunkman
@Dijo
How did you enter your physical SIM card number?
Are you able to access your self service account?
https://www.publicmobile.ca/en/ab/get-help/articles/change-sim-number
@hTideGnow
For future reference, with the ticketing system fixed last week, Public mobile prefers customers submit ticket for customer service agent support instead of private messaging.  It should provide quicker response times (since account is verified) and better tracking by PM for different problems.
To submit a ticket, start with the chatbot.  Or the following link:
hi @Dijo you need support agent to help to update the sim card number.  Please also ask support to check the setup
please submit a ticket with CS Agent here:
