03-04-2023 10:02 AM
Hi,
Just wondering if I'm imagining things. I'm on the 15$ plan , 100 minutes and free incoming.
Have the terms for what is charged against your minutes changed recently for incoming calls if you're out of province?
I'm in Montreal, so my "home province" is Quebec but I often go to Ottawa to visit family. I was checking my usage and was charged 34 minutes for an incoming call I received while in Ottawa this week.
After checking the "fine print" on the 15$ plan terms, #2 says you will be charged minutes if you receive incoming calls while you are out of your home province.
Has this been changed recently? Was it always like this?
There is a strong possibility that I never noticed before in my 4+ yrs with Public, but I think I would have, because I've had a few long conversations out of province that would've used up most of my minutes.... Thanks!
03-04-2023 05:50 PM
Turns out there was some sort of momentary glitch in my account and it has now gone back to what it should be- Canada-wide free incoming minutes. Thanks for your replies!
03-04-2023 05:49 PM
Hi, I was checking the incoming minutes against the 100. I had a 35 minute incoming call when I was out of province and it seemed to count against the 100. After I opened a ticket, turns out there was some sort of glitch in my account and it reverted back to what it should have been, ie free Canada wide incoming. Thanks!
03-04-2023 01:44 PM
When your are on the $15 plan and you look at your My Account it shows information or mis information and refers to the provincial plan. So @mischt you need to verify if you are on the Canada Wide or Provincial $15 calling plan. Unfortunately your My Account no longer shows what is included in your $15 plan like it used to. How are your verifying the inbound calls going against your 100 minutes......from usage or checking on minutes left?.
03-04-2023 11:08 AM
will do!
03-04-2023 10:57 AM - edited 03-04-2023 10:57 AM
@mischt no worry, I think it is an easy ask
If you are with PM for 4 years and you didn't change to the $15 plan in 2021 when Provincial wide plans were shortly offered, you should be fine
03-04-2023 10:57 AM
@mischt Anything is possible 4 years ago when I joined PM it was for the $25 plan and it was province wide then … didn’t really pay to much attention to the $15 plan so couldn’t say for certain … but as @softech mentioned if you call forwarded the number that could be reason . Otherwise you should be good for unlimited in coming calls no matter where you are in Canada … let us know what you find out …
03-04-2023 10:52 AM
There must be a glitch in the system somewhere as they switched the terms of my plan or something....
03-04-2023 10:52 AM
It very well could be ! I will open a ticket to find out, as it would seem to be the only way to figure this out!
03-04-2023 10:51 AM
@Handy1 it is , i just explaining the term does not apply on OP situation.
Also, incoming calls are always free, except in the case that the call was forwarded.
03-04-2023 10:51 AM
Thanks I will open a ticket to find out!
03-04-2023 10:47 AM
@softech So my very first reply was correct ?
03-04-2023 10:31 AM - edited 03-04-2023 10:45 AM
the fine print #2 is for Province wide calling plan. Provincial wide calling was only offered a short period of time in 2021. If you have been with PM for 4 years, you are on the Canada wide calling
@mischt wrote:I was just charged 34 minutes against my free 100 minutes for an incoming call while I was out of province.
did you use call forwarding? forwarded calls will be charged against your outgoing minutes
If the 34 minutes call you got charged was directly calling your number and you didn't used call forwarding, open ticket with PM support and ask them to add it back the 34 minutes to your account
03-04-2023 10:18 AM - edited 03-04-2023 10:22 AM
@mischt huh well that’s news to me I don’t see that in the website anywheres but I’ll take your word for it
Adding my guess then is always like that because I know then$25 plan used to just be province wide and it’s now Canada wide
03-04-2023 10:15 AM
Thanks. They say it is only province wide, and you will be charged when you are out of province. I'm wondering if it ha always been like this, or if it has changed recently.
03-04-2023 10:12 AM - edited 03-04-2023 10:13 AM
@mischtclear webrowser and try again incognito private mode you are probably seeing old cached info
Try again incognito mode/private mode or a different device or lap top or simply try refreshing the page when logged in
03-04-2023 10:09 AM
@mischt maybe get support to investigate it’s my understanding incoming and out going are Canada wide and 100 mins bucket is for outgoing only
Watch for reply top of page to the
Right ( envelope image )
03-04-2023 10:06 AM
03-04-2023 10:03 AM
@mischt No you can use it anywheres in Canada and it’s still unlimited incoming calls it’s just the 100 out going calls
