tablet
03-04-2023 03:24 PM
can i use my cell number on my tablet same time ( can i & will it work if i put another sim card into my tablet so i can use both with same phone number
Phones
03-04-2023 06:26 PM
You have 3 options:
1) Move your sim from your phone to your tablet as needed. This will only allow one device to be used at a time.
2) Leave the sim in your phone and connect your tablet to your phone's hotspot.
3) Purchase a second sim, activate a second account, and pay for a second plan for use on your tablet.
03-04-2023 03:29 PM
Hi @tony90 PM does not block the use of its sim card on tablet. Just pop the som card from your phone and insert it into the tablet and you can use the data. For voice, make sure it has a dialer app installed
03-04-2023 03:26 PM
@tony90 while the sim card can be used on the tablet, only one device will be connected at the time. Only the device has the sim. card, whether phone or tablet, will have the PM service
03-04-2023 03:25 PM - edited 03-04-2023 03:27 PM
@tony90 NO, Your best to just hotspot your mobile data to it
