4 weeks ago - last edited 4 weeks ago
At Fizz Mobile, you can get rid of text, voice, voice mail from your plan and get just the data for less price. I just need the data. I don't want to pay for text, voice and voice mail features that I'll never use. Please give us a similar data only option so that we can enjoy the data on a tablet. Ideally, a larger amount of data would be perfect. Thank you Public Mobile team!
4 weeks ago
hi @Keplr
there was never a data only plan. Data is so cheap la and I don't think it will lower the bill anymore if they remove voice/text. Just get the plan that has data amount you need and ignore the calls and texts
and this is just Community and only customers are reading the posts. If you really want PM agents to hear your voice, you need to submit them a ticket
Submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
(If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit ticket by direct message:
