locked out after one attempt - help!
ggraziani
My son was logging in and locked out after one attempt (using the correct email and pswd). How do I contact a moderator to sort this out? Thanks!
12 REPLIES 12
John_G1
but if the card no longer has a valid number (because new card issued), then that will not work. I suspect an agent will be needed.
ggraziani
thx will get him to try the *611 thing. not sure about cc or voucher... in communication with moderator so fingers crossed.
@ggraziani
@ggraziani wrote:
nope - just today after one attempt at logging in. he'd run out of data and needed to add more. phone has been working fine until today. thx
@ggraziani hi you can add more data by dialing *611 on his phone with a voucher or credit card on file
ggraziani
@ggraziani wrote:
thanks. but even in incognito just get the same locked out message and not able to change pswd.
@ggraziani hi was the account suspended more than 90 days? if so the account is closed permanently
ggraziani
ggraziani
thanks. how do you go incognito?
@ggraziani
Website can be finicky.  You can try again in one hour.  Clear cache or incognito mode.  I had similar issue with one of my accounts also a couple of weeks ago.
ggraziani
thx - tried resetting pswd - no luck. Just sent message to moderators. Thank you!
Staliger
@ggraziani You can either create a ticket by clicking on ? on the bottom right side of the page or by sending a direct message here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Triguy
He could try the forgot password link.
https://selfserve.publicmobile.ca/forgot-password/
Here’s when and how to contact the Moderator Team:
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to the Moderator Team. Click here to get started.
  • Alternatively, you can send a private message to the Moderators by clicking here. You’ll need to be logged in to your Community account for the link to work.
