locked out
DJ61
I am writting in my wife's account. I am her husband and I am locked out of mine for no reason that I know of.  We have been public mobile customers for over 5 years. Can I get help?
2 REPLIES 2
HI @DJ61
your wife even login to My Account after EverSafe was used as the login system last year?
But the problem could be just browser cache, please use Incognito/private/secret mode on your browser to login My Account to confirm again
If same,  please submit a ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
(they might not like your work on your wife's account using your own login, but you can try. Worst case, you might need to create a temp new account for your wife and use that to ask for your wife account problem)
Has the resetting the password been attempted?  A lockout usually last one hour.  If resetting the password doesn't work and it's been longer than one hour, please open a ticket using the chatbot.
