09-30-2023 10:09 AM
How do I change my address and credit card info? I have tried several times through the My Account website and have been unsuccessful.
09-30-2023 03:43 PM
Thanks for the reply. Had Eversafe ID. Worked better on my phone tha my PC.
09-30-2023 03:41 PM
Thanks for the reply. Worked better on my phone than my PC.
09-30-2023 03:38 PM
Thanks for the response. Worked better on my phone than my PC.
09-30-2023 10:42 AM
Like @Dunkman said. Website is finicky. Try this.
How to change credit card on phone app
Download the app from the app store if you already haven’t.
Sign into your app.
When your app opens you’ll be in the My Account tab. You will see a plus button at the bottom left above the My Account tab. Click on it.
Once you’ve clicked on it, go to Payments
The next screen you’ll want to click on Manage Subscription.
The next screen will give you the option to change your credit card information when you click on Manage Payment Method.
There you will be able to enter a new credit card and expiry date. Click on Save and you're good to go.
09-30-2023 10:40 AM
hI @RTinEL
wait an hour and try using Incognito/Private/secret mode on your browser
To change address, My Account, Profile and click the pencil besides the Name
To change credit card info? Go to Payment, Manage Subscription, update card information
09-30-2023 10:24 AM
Website is finicky. Try a different web browser, clear cache or incognito mode. Or try a a different device. Or try on the PM app.
09-30-2023 10:15 AM - edited 09-30-2023 10:20 AM
From your computer log in to "My Account", select "payments" on the left, select "add funds with credit card" and click on the edit button next to the card that you have registered at the moment.
Using the PM Mobile app just click on the plus sign and go to payments. Same steps.
09-30-2023 10:15 AM - edited 09-30-2023 10:17 AM
Did you create an Eversafe ID before login to your account?
Click on Sign Up and create an ID.
When change your CC in the Payment section and your address in the Profile section.
