will "CNY $10 off for 8 months" promotion ends if I change plan from $35 to $40?
sanjayjay
I am currently on $35 per 30 Days Plan with "CNY $10 off for 8 months" promotion .
I am planning to switch to 30-day plan ( $40 ) , if I switch am I going to get $10 of for remaining months?
11 REPLIES 11
cglminsky
I believe that $10 off for 8 months will stay if you keep your plan above $35/m.
@sanjayjay
Click on the (?)  at the bottom right corner of the screen and submit a ticket via simon explaining your issue. Choose account specific issue and then type human. Follow the prompts to submit your ticket. Keep an eye on the envelope icon next to your avatar at the top right corner of the screen for a little number to pop up indicating a message from the moderators. Responding promptly to messages will speed up service times.
sanjayjay
How to check with Mod, sorry I am new, so asking
scorpio17
Don't change the plan yourself. Try to ask moderators about your problem. Maybe they can change your plan for you without losing this promotion.
mpcdesign
@sanjayjay , Don't do it. You are better off with the CNY promotion unless you see yourself saving with the other plan!
@sanjayjay
There was another member who had the 1gb bonus from early December who scheduled a downgrade from the $35 plan with the same lose your promo conditions. Surprise he ended up keeping the 1gb bonus. He took his chances and lucked out.
     You could contact the moderators and ask if you upgrade will you keep it? I would say nothing about what happened with the other member*. If the moderator says no you can then decide if you want to take a chance on scheduling it. You will get double the data that you have now for $5 more if you do lose it. Do you call the US or international much? If not the losing the minutes isn't a big deal compared to getting a lot more data. Decide....do you feel lucky? You have to consider losing the $10 discount too....
* Could be a glitch in the system and you'll keep it....or maybe not?
Edit: When the other member scheduled the plan change on next renewal the system did not warn him he could lose his bonus...so you could test your bonuses by checking out a plan change and if it doesn't warn you then you should be ok. If it does then don't submit the change.
fujiyama
Normally yes, you would lose the discount as others have already explained. But since you are going up a tier, it doesn't hurt to ask message the mods to see if you can keep the discount.
The $40 plan was also eligible for $10 off, so you never know Robot Happy
ddeep91
@sanjayjay  you will lose the promotion if you change plan as @gblackma  mentioned.
Also to add to that
 If you switch your rate plan, OR fall into a suspend or inactive state while on the promotion, you will no longer be eligible for this promotion.
Cheers
ddeep91
Also to add to that
You can read more about it https://productioncommunity.publicmobile.ca/t5/Announcements/Limited-time-offer-Get-up-to-10-off-for...
ddeep91
@sanjayjay
As @gblackma  said above if you switch your rate plan you will lose the promo.
Also to add to that if you fall into a suspend or inactive state while on the promotion, you will no longer be eligible for this promotion.
You can read more about it here
gblackma
No you won't @sanjayjay . It was one of the rules of the promotion, that if you switched plans, the discount would be cancelled.
