07-27-2023
11:14 PM
07-28-2023
01:14 AM
computergeek541
I purchased an esim and a plan for a relative who was visiting from abroad. I completely forgot to cancel the automatic payment before my relative left the country. So now I am unable to get into the account to cancel the subscription because of the two-factor authentication. Please help.
07-28-2023 06:57 AM
I will try that solution. Thanks.
07-28-2023 06:56 AM
Unfortunately I don’t remember their security pin.
07-28-2023 12:50 AM
If you remember their registered number and security PIN. Dial 1-855-4PUBLIC and you can disable AutoPay. After 90 days, the account will be closed, SIM rendered useless and number will be lost.
07-27-2023 11:36 PM
07-27-2023 11:31 PM
Since it is a relatively new activation with eSIM, the account should be signed up with everSafe Login. You can resend the code to the email address associated with account. Then turn off pre-authorized payments. Once account is suspended over 90 days, the account will be permanently closed.
