05-21-2022 07:41 PM - last edited on 05-22-2022 01:08 AM by computergeek541
hi. not sure if this is the right portal. i bought a used phone from PM a month ago and now the battery won't hold a charge. who to i contact about the warranty?
thanks.
bruce
05-21-2022 11:09 PM
thank you so much.
05-21-2022 09:45 PM
Hopefully for your sake it is just under the month of it is right on the month or a day later connect with a CSA to see if it can still be returned under the circumstances, otherwise you will have to do the warranty protocol
05-21-2022 07:53 PM
@bruced wrote:hi. not sure if this is the right portal. i bought a used phone from PM a month ago and now the battery won't hold a charge. who to i contact about the warranty?
thanks.
bruce
Here's some light reading for this evening....
https://www.publicmobile.ca/en/on/get-help/articles/phone-warranty-returns-repairs
05-21-2022 07:48 PM
Hi @bruced open a ticket with PM via messaging them here
05-21-2022 07:47 PM
If it is less then a month, you are eligible for phone return. Otherwise it is warranty repair.
Contact agent for further instructions:
To contact CSA-agent, there are 2 methods:
If ticketing does not work very first time, contact agent directly.
