04-23-2025
11:26 PM
04-24-2025
12:10 AM
computergeek541
04-24-2025 10:55 PM
I was in the same situation last month and tested a few options. If you want to avoid expensive roaming fees, an eSIM is the best choice. There is no physical SIM swap, instant activation, and it is way cheaper than most local plans.
Some providers like YohoMobile even have discount codes floating around. I found ESIM4TRAVEL via a travel blog and it worked.
04-24-2025 04:49 AM
The TextNow app also works in Europe.
04-23-2025 11:42 PM
download WhatsApp to your cellphone. You'll be able to talk / text for free with family/friends at home who also have that app. You'd be using your local wifi in Europe or separately purchased data.
04-23-2025 11:29 PM
for 2 weeks, get esim: Airalo or Saily, or physical sim card like Three network, you can buy from Amazon before you trip
04-23-2025 11:28 PM
hi @Kasinek
PM cannot help with that, they have no roaming service
best is to use travel esim like Airalo if your phone supports esim. If not, buy local data sim
