us roaming
02-09-2023
02:50 PM
02-09-2023
04:33 PM
computergeek541
02-09-2023 04:32 PM
A loonie a day for talk+text or a twoonie a day for talk+text+data (3gb over 15 days or an average of 200mb/day). Waaaay cheaper than the $12 to $16/day Roam like Home charges by most providers that use your monthly plan features. There's a few tricks, tips and glitches you should be aware of and the limitations of using T-Mobile's 2G network for voice calls while we await the implementation of VoLTE.
When you time have a read of this post and the update post so you Roam with eyes wide open....
02-09-2023 03:06 PM
Yes Roaming is $15 for 15 days and you need to connect to T-Mobile while you are down in the US.
It is a lot cheaper than other big 3.
02-09-2023 02:53 PM
HI @LaurieMcLellan not that much 🙂
just $15 for 15 days
you are getting the talk text? where you are going? Make sure you know the Talk is using T-Mobile 2G network, it might not work well.
02-09-2023 02:51 PM
@LaurieMcLellan 15 days for $15 is correct. Used to be 10 day roaming packages but PM just increased the number of days. Good value on the whole compared to other carriers.
02-09-2023 02:51 PM
