Coverage in Maui
EricaWP
I am travelling to Maui and looking to get the “Canada-US-Mexico 5G 60GB” plan.
Wanting to make sure I won’t need to purchase a US Roaming add-on to this to get reception there?
Also, I checked Public Mobile’s coverage map and it says that there is no coverage in Maui but from all the other posts in the community, I am assuming it gets pinged off T-Mobile or AT&T, so I would still be able to get coverage?
1 REPLY 1
@EricaWP
Since Hawaii is part of the USA. You are good to go. Remember to enable Roaming (no roaming charges with PM). It will connect to AT&T, T-Mobile or Verizon.
Your phone must have VoLTE for calling since 3G has been decommissioned in the USA. Here is more information and to check if your phone is compatible by entering the IMEI of your phone in the bottom of link.
https://www.publicmobile.ca/en/on/get-help/articles/volte?_gl=1*1qks5fo*_gcl_aw*R0NMLjE3MzA4MTg5ODgu...
