update credit card
Mom3
Does not allow me to update my credit card info
1 ACCEPTED SOLUTION
Accepted Solutions
@Mom3   could be multiple failed attempts and the Fraud lock kicked in
Please open ticket with PM Support and have them to check
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
**Monitor your Community inbox (envelope icon on the top right) after the ticket is opened.  CS Agent will reply you there
18 REPLIES 18
MrSpock
@Mom3 hi have you tried removing your card instead of updating? sometimes that works
H i@Mom3   What was the error message?
Try using a different browser or use Incognito mode and try again
I suggest you to use Replace this credit card option.  It is much better than delete and re-add (delete and re-add likely give you error)
RossN
@Mom3 hello clear your cache use a different browser use ingognito mode reboot your device
Mom3
will give that a try, thank you
Mom3
thank you for your help
Mom3
i will give that a try thank you
Mom3
I appreciate everyone's help BUT did not work.  I have
  • cleared cache
  • tried different browser
  • cancelled card, tried to add new card
  • called my credit card company and is not them refusing as Public mobile keeps telling me
  • incognito did not work
I am so frustrated!!
roses
Having the EXACT same issue.  All I need is to update my Expiry Date and CVV.
The simplest things are almost impossible with this company.
