HI @wongbett
I think too many failed attempts for adding the credit card. You need to open ticket with PM Support and have them to check it for you. They can unlock if it there is any kind of fraud lock
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
start by typing : Contact CS Agent
then Click "Contact Us"
then Click "Other"
finally Click "Click here to submit a ticket"
