07-07-2022 03:13 PM
i have an account, but I do not remember my email or login information
07-07-2022 03:19 PM
HI @LexWall You tried Forgot Password there and that didn't help too?
then you will need to open ticket with PM CS Agent:
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
First type: "Forgot log in information"
Then Click "Contact Us"
Finally Click "Click here to submit a ticket"
Once ticket is submitted, make sure to check your Community Inbox(top right corner envelope icon) periodically for response from PM's CS Agent
07-07-2022 03:18 PM
@LexWall Hi if forgot password doesn’t work contact a customer service agent
1. you can open a ticket through Simon here https://publicmobile.ca/chatbot.
2. alternatively you can private message them here
07-07-2022 03:17 PM
You should have got an email from PM welcoming you to PM so do a search in your possible emails.
07-07-2022 03:16 PM
You will need the help from a CS_Agent to help you access your account.
They can be reach on this Community page by Creating a Ticket through SIMon Chatbot or private message them.
